The first virtual IP configured on a VRRP interface is the primary virtual IP. After you create a VRRP interface, you can create secondary virtual IPs.
Create primary and secondary IP addresses on the VLAN.
Create a VRRP instance on the VLAN.
Configure a primary virtual IP.
Secondary virtual IP addresses must be in the same subnet as a Secondary IP Interface on the VLAN.
- Select VRRP.
- Select the Interface tab.
- Select an interface, and then select AssociatedIPAddr.
- On the Address List tab, select Insert.
- Type the IP address.
- Select Insert.
Address List Field Descriptions
Use the data in the following table to use the Address List tab.
| Name | Description |
IpAddr |
Specifies a secondary virtual IP address. |
